Use this procedure to display MLD snooping interface parameters.
Switch:1>show ipv6 mld interface
Mld Interface - GlobalRouter
IF STATUS VERS OPER VERS QUERIER Wrong Query JOINS MODE
P1/3 inact 2 2 2001:0db8:3c4d:0015:0000:0000:1a2f:1aaa 0 0 pim
V666 inact 2 2 2001:0db8:3c4d:0015:0000:0000:1a2f:1bbb 0 0 pim
Switch:1>show ipv6 mld interface vlan 10
Vlan IPv6 Mld
VLAN QUERY QUERY ROBUST VERSION LAST SNOOP SSM DYNAMIC
ID INTVL MAX LIST ENABLE SNOOP DOWNGRADE
RESP QUERY ENABLE
10 125 10 2 1 1 false false enabled
Switch:1>show ipv6 mld interface gigabitethernet 1/11
Port IPv6 MLD
PORT QUERY QUERY ROBUST VERSION LAST DYNAMIC
NUM INTVL MAX LIST DOWNGRADE
RESP QUERY
1/11 125 10 2 1 1 enabled
1 out of 1 entries displayed
The following table describes the variables for the show ipv6 mld interface command.
| Variable | Value |
vlan <1-4059> |
Displays MLD snooping information for the configured VLANs. |
gigabitEthernet {slot/port[/sub-port]} |
Displays MLD snooping information on a specific interface. |
